right here goes, not very familiar with smallframe engines but have one in bits now,i need to know whether between the flywheel side bearing and the casing is there a spacer?it shows one in the manual but cant seem to find one anywhere or is it not needed/superceded?,i am using a one piece bearing
any feedback appreciated
dave
vespa 90 question
- hobospeed
I'm pretty sure the original "small door" small frames used a spacer. These are the engines with smaller cylinder spigots and two pronged sliding dogs in the gearbox. Here is a parts book that shows the spacer you are talking about:
I'm pretty sure they did away with this spacer when the original primavera came out.
Tim
Tim
