runninig in rapido 225
steve chapman
couldnt get squish any lower unless i didnt use a gasket , af advised me not to
J1MS
steve chapman wrote:couldnt get squish any lower unless i didnt use a gasket , af advised me not to
Take no notice of AF... anyway what does he know.... :lol:... only kidding Ray if your reading this...
But really it does need to run at, or less than 1.5mm.... or it will more than likely suffer from premiture ignition ( Detonation ) causing a loss of power and possible overheating problems.... I run mine without a head gasket to bring the squish down but kept the base gasket on... and its been fine... :)
Dimitrios_231
No head gasket for me,too.
Otherwise the squish was around 2mm.
Matty
Me too. Base gasket only, Wellseal on head, squish 1.32.
1.2 to 1.4 is the way to go.................. :D
