Can I ditch the fuel drinker
simonwwfc
At the moment I've got a 30mm dellorto carb that was fitted by previous owner it's running along side 186 imola , taffy replica pipe , pacemaker box , bgm 120 stator , lightened fly wheel . It runs a open mouth carb and I've noticed the amount of fuel spit / wastage I'm wondering if the carb is just too big and if so what size to chop it in for .
10 inch Terror
Xbox live gamer tag: No.
If I'm not mistaken the Imola was designed to run with a 30mm Dellorto carb, so I'd say it's ok to use with your set up. What are the condition of the reeds like and Is it jetted properly? Damaged reeds would cause some spit back.
Timbo
Has it ever been on a dyno? Get it set up properly.
simonwwfc
Was set up by chisel speed with dyno by previous owner . They rebuilt it
thackers
God know's i'm no expert, but I thought spit back was all down to port timings/openings, if so a change of carb won't cure the problem. Perhaps a reed valve might do the trick and save on petrol too :?:
CPH Lambretta
Main scooter: DL 150 1970
Imola kits do have reedvalves.
Slow is the new fast!
thackers
Told you I wasn't an expert :oops: ;)
camel
could be reeds or overjetted as previously mentioned,could you run a filter?have you the clearance...i run a foam filter sticking out of the panel on my ts1 and a breathe sweet behind the panel on my reed mugello which keeps everything clean
simonwwfc
Breath easy no as bought one and the panel won't got on next step is I'm gonna try a custom made panel grill by chas speed fabs . It's only just been dynod by chisel speed but gonna need doing again once I get new exhaust back from chromers
purple_pill67
Main scooter: Jet200
what about MBs filter?
isnt spit back due to bad porting timings?
    Users browsing this forum: No registered users and 21 guests
