Vespa PX Casings, converting to Reed Valve
I prefer using the original cranks if possible .
let me know about the T5 crank if you would like it doing ,but i have to charge more for those as there is more metal to remove from the wider webs :)
Bifter
Main scooter: vespa p210
Why not just get a set of LML casings ?
GLscoot
Main scooter: Vespa GS150
i have a set of LML casings, but the conversion for a bigger carb, means I have to fit a fuel pump. which apparently causes more problems than its worth. I will try and make things clear in a few weeks when i get my winter project of the ground.
I will start with the LML casings and see how I get on but i would like to use this manifold from SIP and others, but it is not compatible with the LML casings.
Intake Manifold Kit MALOSSI
20149130 NO.
X360 Reed Valve, for PHBH 28
/30/VHS 24-30/TMX 27/30/PWK
28/30, for Vespa 200 Rally
/P200E/PX200 E/Lusso/`98/MY
/Cosa 200
outlet: 30mm, connection
carburetor: 35mm,
reed valve, rubber connection
joeythescooterboy
I can vouch for both a P2 and a T5 crank done by Sean, it was actually a shame to use them they looked that good.
Nemo saltat sorbius, nisi infanus est.
Bifter
Bit confused here as i had one of those malossi manifolds on my LML 166 with a 28m dellorto carbon reeds mec cur crank and revolver pipe ,used to fly off the clock but would always seize at about 50-55 up hill :?
GLscoot
I can't understand why it does not fit either, but both beedspeed and LTH said it does not fit. The casings I have are the reed valve casings, there not modified. I don't know if it is the fixing screws of the manifold to the casings which don't match. If you have a picture of the engine that would be a great help. I don't want to fork out £140 and be stuck with the manifold. I agree with the engine set up being able to fly. I had a Polini kit and the standard LML reed set up and it lifted the front wheel in first and second everytime. Unfortunately the scooter got knocked over and the casings incurred a hair line crack which I did not notice for about another 1000 miles until the engine started to scream as the crack got bigger.
Bifter
GLSCOOT try lmlocgb forum ,im afraid i dont have the engine or any pictures but i'm sure someone on there will be able to help
    Users browsing this forum: No registered users and 28 guests
