Ugly duckling ?
carlos fandango
Cheers Gerry thats great thanks for the info :D
carlos fandango
A bit more progress. I glued the horncast and mudguard back together with super glue along the original glue line, and strenthend on the inside with a bead of Gripfill/ no nails :D proper job :D
Im a bit stuck still on the flywheel :cry: so i decided to put the engine back together and look for a flywheel in the future. The switch is unrepairable so i need to look for one of those as well.
So ive got the engine back in :)
Russ
carlos fandango
Well, this is (almost) back together, but its gone on the back burner as i do my other project.
Im still after a flywheel (cheap) and switch. :wink:
Russ
carlos fandango
Well its been nearly a year since ive posted any progress with the lince, ive been to busy with other things to do much on it, so its had to wait .
As i couldnt find a Lionelli switch, I got a CEV one from scooter restos which after a bit of rewiring i got working correctly.
I managed to get a flywheel from IOW rally parts fair of all places :D
The engine when i rebuilt it had a crack on the transfer port , i only noticed at the last minute :( so put the engine back together and thought id get it repaired at a later date. Anyway this was playing on my mind so last month i stripped it down again and got it welded :)
And ive just managed to get a seat as the original one was missing the lock. The old seat is of sheet metal construction and the new one is a sprung seat just like a std seat, so not sure which one ill use yet, i may just swap the lock over :)
So all i need now is the registration
DigDug
Well done that man.
Looks great. 8-)
Did you have to do that?
Nice job russ well done
elb1
Main scooter: eibar s2 li150
Bit like marmite the ole lince love em or hate them.. I love them!
Crackin job at very little money 8-)
storkfoot
Well done, Russ. I love it. So, is it a GT200 on a standard Motoplat Electronic ignition and crank?
Fireman Ash
Love my Series 80, it is what it is, Lambretta history ;)
gerryjunior
Xbox live gamer tag: no
Playstation gamer tag: no
Main scooter: lambretta li 2
well done , i like these scoots , they were very smooth to drive, i recently came across the original screen from that scoot ,,
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
