SX Li Crank Big End Gap
Lamaddict
The crank came out of a running engine. I've always replaced TV SX cranks but this is a different situation, long story. I'm shocked by the gap between the con rod and the crank web.
The side float should be in the 1.1 - 1.275 mm region, max 1.5 mm
I think the rod should be centralised by the fitting of piston shims? Were any fitted when you took it apart?
Lamaddict
rosscla wrote:The side float should be in the 1.1 - 1.275 mm region, max 1.5 mm
It wasn't me that took it apart but the new piston will not have any shims but I guess the new piston it's slightly wider so it should centralize. :?
Lamaddict
I've just married up the piston to the small end and there's room for shims so I'll get some in.
    Users browsing this forum: Google [Bot] and 26 guests
