new 5/6 plate clutch for lambrettas
sydduckett
Fux wrote:After a lot of messing about I gave up on my af road and bought a couple of these instead. They havn't turned up yet so can't give you a report.
what problems did you have, seems some are okay and some are not machined correctly. and I know which one I would get.
Fux
Main scooter: li150 S2
I had to machine mine. Both the spider and the basket and it still couldn't handle my rb, so I threw in some race plates and sold it on.
Fux
Hi guys, recived both a 5 and 6 plate from Lee today, are these plug and play, or should i soak the plates as per normal?
Fux wrote: should i soak the plates as per normal?
that should not be nessasary
joespeed
no need to soak the plates and use light gear oil to fill the crankcase!
sydduckett
Sorry to ask again but is Lee,s a cassete type clutch?
sef
joespeed
no ,mine is a 6 plate super light and handles my 30hp ts with no problems,a very good quality cheap clutch,downer needs a 5mm packer!
lee,i need another clutch asap for my next project
regards
joe
Fux
Hmm.. Really? I just fit my 6 plate without a packer. Different type? Or have I buggerd it up ..... Again?
joespeed
6,mm packer as instructed
Fux
I have the New type. No packer required.
    Users browsing this forum: Baidu [Spider] and 5 guests
