wires everywhere
jbg584
Main scooter: Lambretta 1960 series 2
Hi
Has anyone got a wiring diagram or knows how to wire up this speedo Its on my sister in laws LML 125cc 2004 she just bought, took the headset of to try and see why speedo light wasn't working what a mess.Loose wies everywhere managed to get head and dip working cant get fuel or indicators to light or fuel gauge to read.
HELP Ray
mick1
Main scooter: Li Avanti 225
Haynes manual might have something.........
ducksta
dont panic when you look at the crimps at the end of the wires they should only fit certain terminals the black is earth as for the fuel gauge etc look at the metal strip on the speedo make sure its clean and the large terminal clips on flush post a pic and we should talk you through it
jbg584
Hi am going to take couple of pics, managed to get lights working cant get single indicator on speedo to flash with each side or where to connect fuel light.
Ray
wack 63
Main scooter: '71 GP TS1
Not sure on a LML but Vespas warning indicator light flashes via a grey wire from the indicator switch. One of the main problems with any of the warning lights is corrosion on the bulb holder contacts and the printed circuit board. Check the holders with a battery to rule them out and use a multi- meter to trace the individual circuits to each warning light.
jbg584
Hi
Cheers will try that
markpryke
Main scooter: jett 200
lml don't have a printed circuit board they just have a rubber bulb holder that push in
