B7 in avanti
sydduckett
Have been told wise to use a B7 in an avanti head as they run so cool. anyone doing this?
ta
Sef
Donnie
Im not familiar with the avanti I have to say, but I do find it hard to believe a b7 is recommended
Donnie.
Donnie
Just did a google and found http://supertune.co/downloads/avanti_fi ... ctions.pdf
Have you not seen the instructions or did you not fit the kit? It clearly says
" Use an NGK B8ES spark plug or equivalent whilst running in then maybe changed if necessary to a B9ES"
Donnie.
Adam_Winstone
I guess that might suit the bike nicely around town if you are running in, however, I'd swap back to the 8 if you know that you are going to up the speed on some faster roads.
OAP
I have to say that I have used a B7ES around town and on a blast and it is fine, Also a customer running one of the heads on a TS1 found that it was better to use a B7Es. But like everything you must keep an eye on it! In cold weather I would be using a 7
sydduckett
OAP wrote:I have to say that I have used a B7ES around town and on a blast and it is fine, Also a customer running one of the heads on a TS1 found that it was better to use a B7Es. But like everything you must keep an eye on it! In cold weather I would be using a 7
from the horses mouth... ;)
I'm guessing your happy man if the heads doing what it's intended for.... :D
Mine hated the b9, and was fussy round town with b8, its sharp as a tack on the work run with the b7 and swap up to b8 for rallies.
Andy Pickering wrote:Mine hated the b9
Mine too, tried one on the C2C but it was really oily.
Ditto, looked like it had been dipped in oil, I took it that it was running to cool :shock: and couldnt burn it off, the b7 and b8 gives a lovely plug under the respected riding ie 7 town 8 rallies.
