ts1 carb
harpo
hi is there a slim fitting carb for ts1 to allow a breath sweet filter to fit under panel don't want to cut a hole in panel and can't be doing with petrol over any thing thanks
Muppet
tmx35 appears t be the fave
C’est la vie
harpo
thanks for that
Strangely enough the TMX35 is actually thinner than the 27 and 30mm versions. I think the 32 is same depth as the 35 but far more people use the 35 so much more jetting info available.
