Another Holed imola Piston....AAaargh
speedy
The confusing bit is that you have two pairs of tights. :lol:
CutdownSpence
Main scooter: 1966 Silver Special
No good using holed fish nets tho :lol:
One Of England's Finest Salad Dodger's.
speedy
Just asked the wife and only tights with a comfort gusset and/or reinforced toe will be enough to completely filter your fuel.Hope this helps. :D
nellyboyo
speedy wrote:The confusing bit is that you have two pairs of tights.
CutdownSpence wrote:No good using holed fish nets tho :lol:
You boys are on the wrong forum :D
Anyway , off down the cave now to drop the engine, take the tank out, replace the carb.......and she thinks I`m going shopping :oops:
nellyboyo
While I was stripping the engine down I found the exhaust half full of petrol ??
This has now totally confused me , my fault finding skills are out the window. :cry:
The petrol was turned off and there was a puddle under the scoot from the exhaust stub I think .
The scoot is telling me something and I can`t work it out.
Any help appreciated
rbgaz
exhaust full of petrol , could be broken reed petals
nellyboyo
Cheers for that , I`ll check
jonny snatchsniffer
pwk copies are hit and miss too
soosh
jonny snatchsniffer wrote:pwk copies are hit and miss too
Sure,float needle jet needs drilling out,did mine to 3mm.Possible float height adjustment required too.
My motor tried to nip up with this carb,luckily its iron so it did that way before it thought about holing the piston.
nellyboyo
Its a stage 6 pwk .....a better quality pwk copy :)
The float height seems fine and I checked the reeds which were fine too. I`ll go in and drill the needle jet out .
Its up and running now and just checked the timing which is 18 deg spot on,
Just waiting for my new tank to arrive.
Still confused by all the petrol in the exhaust though ????? a good half pint sitting in it ???
    Users browsing this forum: No registered users and 26 guests
