RAPIDO 42 BHP to start with.
Post your Lambretta dyno graphs here! But graphs & spec info only, keep the chat in the 'dyno chat' section ;o)
fairspares
Street Lambretta up to 210cc
1602 Mark Kelly Lambretta 200cc 17.48 18.04 18.08 @ 71 17.48 @ 70 18.37 @ 69 17.71 @ 71 18.02 @ 70
Superstreet Lambretta over 210cc
1650 Alan Dixon Lambretta 250cc 16.20 16.48 @ 78 16.24 @ 78 16.20 @ 79 16.90 @ 77 16.71 @77
Top Scooter Race Scooters over 210cc
1930 Shaun Fairhead Lambretta AF 250cc 13.46 13.56 13.46 @ 91 13.59 @9 2 13.63 @ 92 13.82 @ 92
fairspares
Having a bit of work done ready for the scooter shootout so ive decided to post some photos of the work Ben has done to the barrel and piston. Piston started to get a hair line crack were the red marker is.
Muppet
does ya boost port break through the liner into the alloy of the cylinder?
C’est la vie
fairspares
Muppet wrote:does ya boost port break through the liner into the alloy of the cylinder?
yes it does thats were you can see the welding at inlet manifold.
Muppet
Ya have a large exaustport and only small support for ya piston on ya inlet side; is it piston rock has caused ya piston t crack?
C’est la vie
fairspares
Muppet wrote:Ya have a large exaustport and only small support for ya piston on ya inlet side; is it piston rock has caused ya piston t crack?
possible, to get the inlet timings the half circle cutout is were there is a thinner step on piston inside and thats were it started to split.
I'm away right now, but will post the Dyno graph for this engine when I get back.
So its not this......
Its this.......
Image by drunkmunkey6969, on Flickr
Which is circa 33bhp & 22.5ft-lbs (@ corr-f 0.955 SAE J1349).....and is actually very good for a Rapido.
lambretta-lutz
congrats - nice work at the engine!
Beware of the machined flywheel it is tent to crack at the three bridges.
A reason why I changed to a variotronic and get off the fan and the extra ring that is press on, as well as weld the rivets.
The weight will be 979g.
KR Lutz
fairspares
lambretta-lutz wrote:congrats - nice work at the engine!
KR Lutz
Hi Lambretta Lutz,
this is an engine from my cutdown 1/4 mile sprinter , its still an on going project, currently having a pipe made to suit the engine instead of the modified franspeed race i was using , the power ended up somewhere around 36 and 38 bhp not 42 , ive been working on a few improvements during this year including different igition and hoping to get back out sprinting next year again.
