px front pivot pin
need to replace front pivot pin on my t5 classic got disc forks in, whats the best way and do i need it pressing out? it is 20mm? before i order one
- sean brady scooters
- Dealer
its an easy job with a press
Everything from '83 onwards should use a 20 mm axel. Easy way to tell is if the link is solid it'll be 16mm but if lattice it'll be 20mm.
