OK to use or not
thackers
I have a rear hub that is showing a little wear along the splines, I value advice and opinions so what do you guys think, Thanks
a.j
For the sake of 50 quid for a new 'un, why use a worn one?
Fux
Main scooter: li150 S2
Get rid.
Iv`e lost 2 rear hubs and I wouldn`t reccomend it to anyone. :o
You should check your layshaft splines too because if they look the same as this hub, you`ll knacker the new one simply by normal fitting.
Completely agree, that looks about 90% worn thru, £40 at restos, and definitely check the layshaft
goldeneye
ive had a couple of mates have real nasty accidents this year regarding rear hubs/layshafts going Bang, just change it mate, its only a few quid, and cheaper than a new paint job/helmet/ underpants etc.
thackers
OK thanks guys, the bin it is. Pity as the chromework is very good on it. I haven't used it so my layshaft is not a problem. I suppose it could make a nice door stop :D :D :D
speedy
Deffo a SIL replacement from scooter restorations if it's a standard hub.By that I mean not a luna or J range hub,as I dunna know what they look like inside or from the picture,cause I've never had one. :D
dave wheeler
they make great plant pots!
GP240
put a knackered rim on it, screw it to the garden wall, wrap yer hose-pipe round it. Buy a new one whey job done.
    Users browsing this forum: No registered users and 38 guests
