Running problems
muffster
Xbox live gamer tag: muffinator233
Main scooter: LI 125 S3
Hi again folks.
It seems to be a problem in all gears. It runs fine up to about 1/4 throttle, after that is seems to struggle and sounds rough.
Jets are 200 and 100.
Fuel flows freely with the bowl off and the float works correctly.
Took the fuel banjo off and petrol trickles out of the hose rather than flows.
I'm running through an in line filter, is this a problem?
Also, the fuel pipe banjo connection on the carb is pointing up, rather than down or side on. So the fuel flows down the pipe then has to travel up to the carb. Does it make a difference where it's connected.
How do I check to see if the choke is over adjusted?
Cheers.
If you're only trickling fuel,out the hose you should sort that first. Try it without the filter.
The position of the banjo shouldn't matter stye tank is higher than the bowl it should flow.
    Users browsing this forum: Amazon [Bot] and 7 guests
