Gp only runs with choke out
Suede Ed
Main scooter: SIL GP200
Tangent continued
[imgImage][/img]
[URL=http://s1107.photobucket.com/user/ ... .jpg[/img][/url]
Got the above exhaust while back, but the ubend recently. as you can see the ubend is miles out. think an AF ubend would fit?
Suede Ed
Back to the subject, retorqued head, carb manifold bolts nipped up, all back together. Runs fine :P F@@king things!
Suede Ed
Can start now on choke and will idle ok for a while then revs start increasing on their own? Bogs and miss fires higher up the rev range? Tried a Jetex 22mm but the symptoms were worse, gone back to the dellorto. like I said it ticks over for a few minutes now off choke, then the revs increase on their own up to sort of half throttle? Worn slide? I have a 25mm dellorto, but got no manifold for it yet...
