drt 24/24 carb
cezeta
ive got a drt 24/24 carb about to be fitted to a pinasco 225. with the higher flow and particularly the bigger feed hole to the main jet will this effect the jetting?
hungdog
You might find you need a smaller main as more fuel will be in float bowl as it fills up quicker, but try it and see. Basically your only restriction now, is the main jet as the fuel will be there all the time. The drt carb stops the bowl running dry at full chat. Or I may be talking b0ll0x...
cezeta
yes you have it right
i read that it would need upjetting but cant understand why :?
im just being cautious on the mrs s scooter so i dont have to fix it again
joeythescooterboy
I would've thought that the main jet will still only flow according to it's size no matter how much fuel is in the bowl?
Nemo saltat sorbius, nisi infanus est.
hungdog
[quote="joeythescooterboy"]I would've thought that the main jet will still only flow according to it's size no matter how much fuel is in the bowl?[/quote]
True but if the restriction was the feeder hole, then you might need a smaller main :ugeek:
what's the drt carb? a 'sorted' spaco?
hungdog
rosscla wrote:what's the drt carb? a 'sorted' spaco?
http://www.sip-scootershop.com/en/produ ... +_400000t5
Cheers,
Jack221
Main scooter: PX221
hungdog wrote:
joeythescooterboy wrote:I would've thought that the main jet will still only flow according to it's size no matter how much fuel is in the bowl?
The flow through the main jet will be affected if the float bowl level is changed. The higher fuel level increases the static head pressure at the main jet. Otherwise all remains the same regardless of any other feed hole size which should already be bigger than the main jet.
livefast_diefat
Main scooter: Vespa Sprint 225
Have you got this fitted and running yet, if so how are you finding it?
One Part Man, Two Parts Legend.
    Users browsing this forum: No registered users and 24 guests
