p2 clutchside oil seal
nam65
Main scooter: t5
hi all
A mate thinks he has petrol in his gearbox oil on a p2
is there any other way of telling if the seal is gone.
thanks in advance for reply's
goldeneye
is it using loadsa fuel? is it hard to start? will it only run with the choke out? you can also get the engine running and warm (probly with choke) and drop the engine oil (which will be like p,iss probably) if the engine revs rise, your oil seal is knackered.
paul d
Main scooter: T5 172 Tv 240
Is it running ok?
nam65
Main scooter: t5
cheers for replys
only problem he seems to be having is it looks like its running a bit lean
even tho its main jet is high at122 standard 200 with pm pipe and drilled air filter,and he is getting what he describes as pinking
at higher revs mainly in 4th timing has been checked with timing disc & strobe.
cheers
cezeta
you can put a bulloon on the breather and rev it. if it inflates its gone.
when it is totally gone it will spray oil/fuel out of the breather
bazman
Try going higher on the main jet, also whip flywheel off and check that seal (oil residue weeping and running down behind stator).
Usually with this it will be erratic running and not dropping off the revs .
By the sounds of it i'd go for timing and or main jet, I've ran a 125 before on a stock 200 with a decent expansion.
gaz_powell
do the tests but i would agree with Bazman
I always set p2 timing at IT
Go bigger on the jets and come down
Like Baz i`ve had a 2nd o/s standard barrel with a pitone running 125
best of luck
nam65
Main scooter: t5
cheers all
I will tell him to try the tips and see how it goes from there
thanks
Jack221
Main scooter: PX221
I like the baloon on the breather idea, I have never tried it but I will next time as a quick check :)
The only way to check the seal condition is to do a crankcase pressure test. Although this is American it still explains it better that I could http://www.how-to-diy.org/4s7X1FiXCN2uS ... ngine.html a foot pump with a gauge and a pump adapter for a football works just fine
Seals can take a long time to actually get to the point where it is obvious there is a problem. On a tuned engine this test could make all the differance and explain random heat seizing or lack of power.
    Users browsing this forum: Ahrefs [Bot] and 9 guests
