Varitronic flywheel advice
Bobble
Hi i am in the process of building a Ts1 240, i am going to use my Varitronic that is currently on my Imola. I was going to need to change the flywheel for the welded version with the increased Hp going through it. I could possibly get the existing one welded because it has the removable fan, but the threads on the boss are not great. What i was wondering was if there was any other Flywheel that works with it ( seem to recall something about a Casa flywheel being one piece).
Thanks Rob
poppygun
Playstation gamer tag: poppygun
Main scooter: GP200 1969
Hope this helps
Electronic ignition flywheel, Gp, BGM
New for 2013 and the final piece to the jig saw for the ultimate Lambretta ignition. This is the new BGM one piece GP flywheel
From mb
Dryballs
The bgm flywheel won't work with a vari stator
Where abouts are you? You could send it to Cambridge lambretta for modification
The Casa Parmakit solid flywheel is a direct replacement.
Bobble
Cheers for the replies was at I.O.W at weekend so did not reply, cheers Soulsurfer will look at the Casa one
    Users browsing this forum: Majestic-12 [Bot] and 13 guests
