Running in Mugello?
Darrell Taylor
Main scooter: LAMBRETTA
Donnie wrote:What plug you got in there???
GOOD POINT possibly a GLOW PLUG, i like to run them on a 9 minimum
Last edited by Darrell Taylor on Wed Aug 21, 2013 12:08 pm, edited 1 time in total.
bazabod_downunder
I'm using NGK B6ES at the moment, I do have some NGK B7ES as well......I'm using Motul 800T, am changing to Castrol Activ 2T....using a 4% mix
tonydevon
Main scooter: '71 GP125
6??? holy crap
b9es in mine
Donnie
Holy crap is right!! Jesus man, 6 is like a lawnmower, get an 8 in there!!! a 9 if you'll be doing long dual carraigeway / motorway miles!!
No wonder its got an over run!!!
Donnie.
Darrell Taylor
when you take the 6 out check for silver deposits on the plug,if any then check the piston (shine a torch down plug hole and a small inspection mirror) to see if its nearly got a hole in it
bazabod_downunder
Only put in the 6 yesterday & did about 25 kms on it, was 7 before....will hot trot & get some 8's tomorrow, would it be advisable to put a bigger main in?
tonydevon
I run mine with a 9, and even just round town work it never fouls or plays up.
I just figured that I would run the coldest plug that was still reliable.
Adam_Winstone
As all of the above responses........ 6!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Throw that straight in the bin! You should be looking 8 or 9 around town/general use, with a 9 for motorways.
bazabod_downunder
Clearly I read some dud info to which I'm not very happy or impressed about, thankfully stopped before any or too much damage has been done, will whip the head off tomorrow just to reassure myself, throw all the plugs I have in the bin & get some 9's & put in a bigger main.
