px125 disc speedo removal
bigmuff
Main scooter: matt black indian gp
Anyone know how to disconnect the wiring from back of speedo on px125 disc. Want to replace the handlebar cover. Do the wires just pull out of the black plastic connector block. Dont want to knacker it as I need it for work in the morning?
bigmuff
Or does the black connector block pull off the printed circuit board? Sorted, pcb was stuck to connector and lifting away from speedo. Grew a pair and pulled them apart. All back and working.
gaz_powell
the block pulls off the printed board - but don t just pull it - it has a sprung clip at top and bottom push them in with a small terminal screwdriver
if you just pull it you can snap the lugs
best of luck
bigmuff
Cheers Gaz. The pcb was stuck to the connector. Sorted now.
    Users browsing this forum: No registered users and 60 guests
