Timing with different casing?
eadmr04
I recently had problems with a twisted crank and damaged casing. I've rebuilt the engine with all the original parts, apart from a different casing, crank, flywheel and new bearings and seals. The top end is the same, as is the mag housing etc. When I set my timing before (17 degrees), the stator bolts sat just off centre. I'm just setting it up statically for the time being on the new set up and I've had to move the stator completely anticlockwise and this still was not enough and have hat to extend the slots as far as I dare go without leaving too little on the ends. Does this seem plausible? It's the BGM stator I was already using and a new mid weight AF flywheel?
Donnie
Are you using the same timing marks on the mag housing as you did for the old set up??
Donnie.
gaz_powell
you problem may be the mid weight flywheel - I had problems with one and it appeared that boss had been put in the wrong position
so the arrow and marks on the window to line up with the pick up were out in relation
in the past I have changed stators on the side of the road and just eyed them up as best as possible (did it on route C2C this year 30 miles in and completed there and back)- always air on caution but been somewhere near.
what flywheel were you using before the twisted crank ? Try the same type of flywheel # if you can get hold of one and see if any difference
best of luck
Gaz
# edited
eadmr04
Donnie wrote:Are you using the same timing marks on the mag housing as you did for the old set up??
Started again using a piston stop to find my new TDC and remarked everything.
eadmr04
Gaz, could be, it's the same make of crank, so wouldn't of thought there would have been too much difference? Suppose will have to wait till Ive got it in the frame and started so I can strobe it? :(
gaz_powell
typo in my reply should have read ;-
what flywheel were you using before the twisted crank ? Try the same type of flywheel if you can get hold of one and see if any difference
I binned the midweight off and returned to SIL lightened the same as the mid weight - no problems with it
if the boss is out you might struggle
faf
Main scooter: GP 230 Mugello
Apologies if this is a stupid question,but how do you set your timing statically,without the engine running and strobing it?
Donnie
Good man, I was hoping you'd say that!
Donnie.
Donnie
faf wrote:Apologies if this is a stupid question,but how do you set your timing statically,without the engine running and strobing it?
Google :?: :D
http://www.smellofdeath.com/lloydy/elec_ign.htm
Donnie.
lambro
Google :?: :D
Good for starting points, and then check with a light once up and running.
