Here's mine:
TS1 230.
JB Stage 2 work on barrel and casings.
60mm - 110mm Rod Corsa Crank.
70mm Super Monza Piston.
AF Recessed Head.
16/46 - 4.9 Drive.
Li 150 'box
MBD Inlet manifold with 5mm packer.
Franspeed Race Pipe.
AF/Surflex 6 Plate Clutch.
Mikuni TMX35 with:
300 Main
6 Slide
22.5 Pilot
58 Needle 3rd Clip from Top.
Dyno'd last week @ JB with 26 bhp at rear wheel.
Lambretta Carb Set-ups.....
lammy ts1 225 standard
carb mikuni 35 tmx main jet 330, needle en11-55 on the 2nd clip and idle 2
franspeed race exhaust and a lightened flywheel with a bgm stator with a augusto 7000 unit
sx 200 gearbox
sx 200 gearbox
- Main scooter: GP RB 240 Taylor Tuned
RB225 kit fitted
Barrel ported and matched to casings, crankcase welded to allow larger transfer ports,
NK Exhaust
35mm Mikuni Carb, 320 main jet, 57 needle (2nd clip) 22 ½ pilot jet, 1 ½ turns out air screw
Ignition 17 Degrees
AF Crank
BGM Stator
Indian Flywheel (AF Flywheel removed - causing engine to 4 stroke)
Foxhat 6 Plate Clutch
16 tooth front sprocket, 47 tooth rear sprocket
Dyno'd by Darrel @ 50cc tuning 30.5 Bhp
Happy Days
hope this helps anyone acheiving a reliable set up
NK Exhaust
Ignition 17 Degrees
AF Crank
BGM Stator
Happy Days
Set up:
Mugello 240
30mm Delly
Breathe sweet filter
50pilot was 60
Av266
x13 needle top clip
125main
350 fuel valve
camlam fast flow
Mugello 225 Touring tune by chisel speed
70mm Ron Moss Avanti Piston (cut skirt by 2mm)
62mm full circle crank
107rod
Head reprofiled by Harry Barlow Proporting 1.3mm squish
Augusto 6000
BGM 80w stator
Af Light Fly wheel
Blue CDi
Ngk N9 Plug
48mm Ron Moss Avanti Exhaust.
19/46 on a GP200 box
Did have a 50mm gori on dyno'd at 22.3Hp @ reedspeed probably more like 18hp with Ron Moss pipe on but not confirmed.
Mugello 240
30mm Delly
50pilot was 60
Av266
x13 needle top clip
125main
350 fuel valve
camlam fast flow
107rod
Augusto 6000
BGM 80w stator
Af Light Fly wheel
Blue CDi
Ngk N9 Plug
set up.
Classic Rapido 200
LI 150 gearbox
16X46 sprockets giving 4.9 ratio
AF 42 mm clubman
Dellorto 30 PHBH open mouth under full panel work
atomiser/needle jet AV266
main jet 122
float jet 300
X7 needle second clip
40 slide
55 pilot
choke 70
mixture screw 3 turns out
Indian static electronic ignition set at 16 BTDC
does about 50 mile on a full standard tank before going on reserve
Classic Rapido 200
LI 150 gearbox
AF 42 mm clubman
main jet 122
float jet 300
40 slide
55 pilot
choke 70
- e_9111
- Main scooter: Lambretta 225 Rapido
Engine: linx 200 , 66,4 old piston modified from 1984 tarabusi 3 rings
cleaned piston flashes , lateral lubrication holes ,
58mm AF crank -
0,8 mm gasket aluminio on head and 0,4 down cilindre
Transfers openend and raised to improve flow for up , exhaust port widenend , port admission polised + 1 port booster 6 mm wide
reeds-boox 2 petals
DellOrto 28+ filter-oiled
55 pilot / 128main / x7 needle 1ºclip down , Av266
fresco pipe + Exhaust insulating wrap
ignition electronic BGM 18º
flywheel normal ; fast flow
17x47 , clutch lightened ; 3% sintetic-repsol ; 4 Plate Clutch , surflex + spring reinforzed
wait 5 minutes to warm engine,,,,for heat to spark plug
118km/h
58mm AF crank -
reeds-boox 2 petals
118km/h
== Enrique ==
RapidoRace 225
RapidoRace 225
Hi,
Has anybody tried anything else than standard slide 6 with TMX35?
I´ve problems with slide area but it´s maybe worn slide.
TMX 35
RamAir
JL Curly
TS1 230 MBD
TMX 35
RamAir
JL Curly
TS1 230 MBD
My set up - i run the same on my SX and GP
Barrel TS1 225 standard no modifications - casings matched to barrel
Head SIL modified by Chiselspeed
Carb Dellorto VHSB34 LD on MB manifold
Main 160
Needle K6
Needle Seat 300
Slide STANDARD 40
Atomiser DQ267
Choke 60
Pilot/Idle B40
Air Screw 2.5 turns out
Restrictor on inlet drilled out
Gearing GP 200 with 19/46
Clutch 4 plate Surflex B with MB springs
Crank SIL Webs and RB rod kit
Exhaust SSC Taffspeed copy
Timing SIL stator, lighened SIL flywheel - set 19 degree
Main 160
Needle K6
Needle Seat 300
Slide STANDARD 40
Atomiser DQ267
Choke 60
Pilot/Idle B40
- red
- Main scooter: Scomadi TL 250 (Ltd Ed No.3)
I'm going to change carbs from the current Dell'orto 24mm to a Dell'orto PHBH 30MM
Main reason for the change is I'm looking at increasing the mpg from the current 24mpg and also the scoot will not run right on the current carb even though it used to but the slide does look worn as does the needle
The carb I'm looking at as the following:
145 main
45 pilot
60 choke
AV 262 Atomiser
40 slide
X2 needle
No float jet present but have been told a 300 will be okay
Gearing is 19/46 Indian GP200
Exhaust is an old style Mark Broadhurst Devtour
Any help will be greatly appreciated,are these jets etc okay,what clip should I have the needle?
Also it will be run without an air filter
145 main
45 pilot
60 choke
AV 262 Atomiser
40 slide
X2 needle
- Andy Pickering
- Main scooter: GP
Main looks on the large side Red
