Wireing help
Fux
Main scooter: li150 S2
When I swapped out my front brake lever I just pulled off the wires that were on the front brake switch.
My brake light worked fine before I did this and Iv`e drawn up a diagram of how the wireing is.
Can someone explain what I need to do to get it to work again?
I had to Ohm the loom because the wireing goes through the frame, so there isn`t any faults.
It`s on a variatronic, if that means something. It doesn`t look like the way i would normally do it.
Fux
Looked at it before I went to work this morning.
The rear light works, so it has power fed into it from black.
The Yellow/red wire isn`t joined to anything at the front so where can I connect that to make the circuit?
mick1
Main scooter: Li Avanti 225
Sorry but looking at your drawing i can't make head nor tail of it ?? If you've got your back light working with power on the black then the black it shouldn't go to your brake light switch ??
Try doing a search to find the nearest wiring drawing that matches what you've got (unless you've got Stickey's) then post make and model of scooter with your suggested wiring diagram and we'll take it from there.
Fux
Thats why I need the help.
I don`t understand what the builder has done and this is what it looks like. On the other hand, this did work before I removed the handlebar switch.
I also think he mentioned something about it being DC.
    Users browsing this forum: Baidu [Spider] and 12 guests
