Early Imola cylinder head.
10 inch Terror
Xbox live gamer tag: No.
Hi guys, does anyone know where I can get an early kit cylinder Imola head? It's the type with the side squish and 4 stud holes. I've tried Cam Lam and Mike Phoenix but they are out of stock until September. Thanks in advance Pete.
Donnie
You have asked for the right one i assume, and I assume its for the one you had a thread about earlier in the week? ie the head with the collets, you don't want a mk 1 head if so, you need to specify the collet version
Donnie.
10 inch Terror
Donnie wrote:You have asked for the right one i assume, and I assume its for the one you had a thread about earlier in the week? ie the head with the collets, you don't want a mk 1 head if so, you need to specify the collet version
Yes mate, I spoke to them both on the phone and neither had any in stock. I've cleaned up my head now and I think it will be ok to re-use it. Thanks for your time Pete.
Donnie
thought you said there's a bit missing off it?
Donnie.
10 inch Terror
Donnie wrote:thought you said there's a bit missing off it?
I've spoken to a grown up and they said its ok to use again. It just needs skimming slightly.
Donnie
OK, just make sure the surfaces are mated properly and you check how the skimming affects your squish mate.
Donnie.
10 inch Terror
Donnie wrote:OK, just make sure the surfaces are mated properly and you check how the skimming affects your squish mate.
The squish was set at 1.3mm so if I take 0.1mm off that should then give me 1.2mm? Which I believe should be ok. Thanks for your comments much appreciated.
Donnie
Don't assume it'll give you 1.2mm, definitely check it when fitted.
Donnie.
10 inch Terror
Donnie wrote:Don't assume it'll give you 1.2mm, definitely check it when fitted.
Yes I'll make sure. What method do you use for mating the surfaces? I'm thinking of using a mirror with some 800 wet and dry taped to it and slowly lap it on that. Is that a good or bad idea? I'd rather know now before I try it. Cheers Pete.
Donnie
Yep a mirror or any properly flat surface will do the job.
Donnie.
    Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 11 guests
