re-facing carb slides
sydduckett
Is this possible? By re facing, I mean re plating the front of the slide to its origonal width using chrome or other medium? I have a dellorto vhsh 30 which goes through a slide a year. I have 4 of them now all with wear on the outside edges. At £60+ a slide it would be handy to have another option.
Ta
Sef
Darrell Taylor
Main scooter: LAMBRETTA
could try running with a good air filter (if u dont already)
Lambretta Sash
Main scooter: Lambretta TV 230
Have used a special coating spray on std slides many moons ago, its about £15 tin :?:
soosh
£60 a slide? Where? Bought mine last week £35 from Eurocarb.
Muppet
Y change the slide; wot about the centre part number 42
http://www.dellorto.co.uk/images/parts/VHSHdiag2.pdf
C’est la vie
that's a vhsb
sydduckett
RICSPEED wrote:that's a vhsb
Yes thats right, mines a vhsh which has the flat slide. Ill have alook on Eurocarb but thats probably the VHSB. Do you have a link?
Ta
sef
soosh
It will be cheaper popping in the shop but i guess you are nowhere near but they should still advise you on anything and give you a good deal.
