SIP Sensor - Front Wheel Mounting
immylam
Anyone got any pics of how to mount this with the bracket with a tubeless front wheel with disc brake?
THANKS.
immylam
All seems to work ok , haven't road tested though.
http://s1289.photobucket.com/user/immyj ... b.jpg.html
What is the sensor reading off fitted there?
I need to try to get mine to work with a standard front disk.
immylam
I put a magnet to the inside of the hub (obviously clear of the calliper) and it reads from that although it can also take a reading from the wheel studs. There are pics on here of someone who set it to read from the rear hub and it looks good with a neat sensor holder.
Minority
Main scooter: Li230 S3
You'll like the electronic sensor!
