30mm dellorto jetting help
Donnie
Is it returning to idle properly now on the 40?
Donnie.
choppersteve1
Main scooter: Lambretta gp200
Does 't hang up forever any more. Doesn't immediately drop to idle, wonder if the richer needle cured it. I was blipping it up to within the needle taper zone, so weak needle effecting return to idle!!! Just re tried with taped throttle, 4 strokey bit is around 1/16 throttle, so nearly shut. Don't seem to end up in that range even when'poodling' along, so feeling kinda happy at the mo! Longer test tomorrow . Thanks for replies .
You can get 41, 42, 43 etc up to 49 in 5mm pilot jets.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
