Aligning Sprockets
Does anyone actually make a chain alignment tool? If not how do you do it, I just wasted an hour with a vernier and clutch compressor bar, a la the manual, and made no conclusive measurement other than the rear sprocket is high, I'm not convinced by the dial gauge method described either, seems to be too much room for error?
bar and vernier (digital best really) should be more than enough
RICSPEED wrote:bar and vernier (digital best really) should be more than enough
Tried that, see above ;) I found it varied everytime I took a measurement...
yeah I know what you mean though without the bar being machined dead flat and parallel you just have to make the best of it
RICSPEED wrote:yeah I know what you mean though without the bar being machined dead flat and parallel you just have to make the best of it
Hmmm I'm gonna have to find a better solution... Cheers Ric :)
You can get ground flat bar off eBay relatively cheaply as you really only need an off cut 200mm or so.
blue
I use a metal ruler stood on it's edge on both gasket faces then measure down from the top edge of the ruler to sprocket with digital verniers, works for me.
Angry Bloke
blue wrote:I use a metal ruler stood on it's edge on both gasket faces then measure down from the top edge of the ruler to sprocket with digital verniers, works for me.
That's the method I use
But thinking out loud , what about a a length of square bar laid ( or fixed to chain case studs ) across the gasket face with a taped hole above the sprocket - then screw in a stud/bolt until it touches the sprocket - lock off with a nut and you can measure as many times as you need to be sure :idea:
Just an idea needs a bit of refinement :D
Interesting, what tolerances are you working to with these methods?
Elite-225
Main scooter: GP 225
Interesting ! .. What sort of lambretta engine are you building ?? .. i use a 12" steel rule & a 150mm. steel rule with a steady ish .. hand . maybe youre thinking too much soulsurfer ? :|
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
