I had it dynoed at Diablo and it makes 18bhp, which is a bit disappointing, but as Alan pointed out, with less than 12 bhp at around 4500 rpm, it's not going to pull the gearing, even with a T5 4th gear. An age old malossi trait.
I had a ride on Alan's Polini 210 and it was much better. Power lower down the rev range, with lots more torque to boot.
I should have listened to Alan in the first place......
Anyway, I have decided to go Polini, but time is tight, and I am not prepared to miss the summer waiting for a scooter shop to swap it for me. So I will do it myself, probably.
What I want to know is, with my current set-up. Harry Barlow put the packer at the top of the barrel. Will this work with the Polini too?
Also will the head I already have work with the Polini too?
Is there much difference in the crank case porting between a malossi and a Polini? Will I need to port the cases again?
Any advice would be much appreciated.
Ps anyone want to buy a Malossi kit?
