Nyloc
bishopsfinger
Main scooter: vespa gl177
Hi all,simple question.Nyloc cylinder head nuts or not? My malossi 210 vibrates so subsequently everything loosens!
gaz_powell
No
Use a thick flat washer, good quality spring washer and a deep nut
Torque it up to 17lbs/ft
bishopsfinger
Cheers mate
AUSSIE
try stover nuts or philidas nuts. both are all metal self locking nuts. http://www.orbitalfasteners.co.uk/en/ca ... tover-nuts
Have you looked into why it's vibrating so much?
Juan
Standard or aftermarket crank?
Aftermarkets tend to be shite so if so good chance it's out of kilter.
goldeneye
use a flat washer, a spring washer, and I use 4 of the longer headcowling distance nuts instead of the normal nuts, torqued to 18 ftlbs.
bristolmod
as I understand it you should never use "Nyloks" or similar self locking nuts on studs that are in alloy. The nyloks/ self locking nuts can lock so tight that it unscrews the thread rather than just the nut.
As stated above- flat washer; locking washer; then plain nut.
Scootering since 1968.
goldeneye wrote:use a flat washer, a spring washer, and I use 4 of the longer headcowling distance nuts instead of the normal nuts, torqued to 18 ftlbs.
and drill them them with 2mm holes both sides and use locking wire :!:
bishopsfinger
Hi all and thanks for your help,found rogue cylinder stud,longer than the rest it had a dodgy thread atthecasing end and ws working loose
