Will a cyclone version 1 be ok with 25hp tune???
ssteam177
Main scooter: vba malossi 221, api series2
I have a monza 225 set up with the following parts
Tmx35 carb
60mm crank with yam 110 rod
Vforce reed
Franspeed race pipe
Will the cyclone version 1 be ok to use with this setup or do I need the version 3
IT'S NOT WHAT YOU BUY
IT'S WHAT YOU BUILD!!!!
twenty eight
i have the second batch mate mine kicks out 25 bhp franspeed racepipe it lasted half hour before it spun in 5th,got the new cluster going in this week.put it in and try hope it works ok for you
giankx
If i remind correctly the V1 was tested on a TS1 with about 25 hp without issues...
