That's interesting, I'm running a BGM 30mm PWK on a TS1 at the moment and it does seem weak on the overrun, think I'll up the pilot.mnpes wrote:.....I"ve found running small pj"s even on original Keihins is not good medicine
Monitoring an original pwk28 carb up with an onboard air-fuel-ratio gauge etc
The small pj"s ran dangerously lean when throttling right back
bgm/mb 225 rt
- coaster
Lambretta Sash
- Dealer
- Main scooter: Lambretta TV 230
Only managed about 2k before plating wore away on thrust facesMinority wrote:Sounds sweet Simon, you've got to be happy with 20k, that's a fair few km!SpanishSX200 wrote:And then what happened?
Minority,
I took it off and replaced it with a reed valved RT, that Mark did for me. Have just completed Avignon on the new kit. The old RT will be getting the same treatment. I can run the reed valved one with an open carb with no spit back. And it gives me another 6-8 BHP.
Simon
Was a good kit once set up 20 hp out of box, its going to be steel linered next time round to ensure no cylinder distortion
- victor
- Main scooter: Tv175 but currently a SS210 :)
MB recommended me against using the PJ at all and supplied my PWK plugged...coaster wrote:That's interesting, I'm running a BGM 30mm PWK on a TS1 at the moment and it does seem weak on the overrun, think I'll up the pilot.mnpes wrote:.....I"ve found running small pj"s even on original Keihins is not good medicine
Powerjet Carbs are good on the right engine ~ But only a few benefit
- Speed Demon
- Dealer
I took it by pj's that he meant Pilot Jets as opposed to Power Jets or Pyjammas
Get to SULK
- victor
LOLcoaster wrote:Me too, power jet's (such as it is on a PWK) blocked off anyway.Speed Demon wrote:I took it by pj's that he meant Pilot Jets as opposed to Power Jets or Pyjammas
Considering how hard the Pilot Jet was to set up (still slightly rich on 35) I wish that that was what was recommended against but no, as stated above, it was the Power Jet
Hope ya get sorted
Minority
- Main scooter: Li230 S3
That's exactly what I thought. They say great minds think alike, so you must be a man of great intellect.Speed Demon wrote:I took it by pj's that he meant Pilot Jets as opposed to Power Jets or Pyjammas
Train Driver
About time someone worked out a fuel injection system
Perhaps someone in the CV postal area
