sip speedo cht gauge and spark plug washers
poppygun
Playstation gamer tag: poppygun
Main scooter: GP200 1969
when using sip speedo cht probe under spark plug do you still use the washer on spark plug ,
as it raises the spark plug or dose it no matter ,any thoughts on this
thanks poppygun
Lambretta Sash
Main scooter: Lambretta TV 230
You can use both washers if necessary to position plug correctly, however it would be best to check position of plug in Cylinder head off first.
I have noticed on some cylinder heads that the position is not to great
