front hub problems
Tosh
my lad complaining about a noise coming from the front,just stripped the hub off and the ribs on the inside off the hub have been rubbing against the
side of the brake shoes and its taken about 1/2 mill of each rib,there is no play anywhere,all fitted as manual say`s..Vespa t5 125 classic..
Juan
Have the little retaining circlips been fitted into the grooves on the locating pins?
Tosh
Hi juan,thanks for the reply i`ve just been on hols down Devon,i`ve sorted my sons front hub probs it was the circlip on
the shaft that holds the back plate from coming forward it was broke in two but still in the grove i replaced it and all is ok :)
