Mito racing oil seal conversion
Speed Demon
I don't think they are first to be doing a single seal conversion - I believe it is recommended on the Super Monza engines.
Get to SULK
TED CRUD
Does that version have a groove in the mag housing
Smash Ya Pastie
Washington Posse s.c
Speed Demon
Never seen it yet, but yes I believe that it does have an oil feed.
Get to SULK
psychedelicropcircle
1950's S1 technology :ugeek:
a.lo.v2
Main scooter: sx 200
this will reduce crankcase compression surely?, the mix having to fill the bearing area as well .
mickdale
a.lo.v2 wrote:this will reduce crankcase compression surely?, the mix having to fill the bearing area as well .
I thought larger crankcase volume was a good thing?
cheers
mick
nelson pk
Speed Demon wrote:I don't think they are first to be doing a single seal conversion - I believe it is recommended on the Super Monza engines.
Yes it is and it does have the oil feed in the mag housing too.
TED CRUD
But is it any good /worth doing ?
Smash Ya Pastie
giankx
I have this conversion on my TS1, and some friends have it on other engines build from Mito.
Can't compare to previous engine performance because i did some porting too.
    Users browsing this forum: No registered users and 66 guests
