PM Tuning Volante antidive disc brake
frank sanderson
Did you get the fitting instructions with your hub ? we tell everybody to fit at 90 degrees in the instructions . If you fit at any more or less you run the risk of the problem you describe .above 90 it trys to push outward instead of toward the fork leg below 90 it trys to push in all the force is transmitted toward the joint in the linkage not toward the forkleg .
MAB wrote:I have just got the Mito twin disc )
very tasty ..
but can you explane .. 90deg in relation to what ..the caliper arm ..links ??
Minority
Main scooter: Li230 S3
very tasty ..
Think Frank means like this (this is a ScootRS setup, but same principle should apply):
Danger
Main scooter: lambretta TV200
The bracket on the fork leg That the anti dive is bolted too can that be bought separately , and would it work with the pm tunning setup and if it can be bought separately where from cheers danger
scroll up I posted a link
Danger
Cheers ric
Danger
I bought a pm tuning anti dive disc brake from tr speed shop but I didn't get any instructions with it would any body have any pics or info on how the hub should be fitted plus it say in the add when I bought it that it was for tubeless rims but the studs in mine are about an inch long at most so there's no way my rim will fit can the studs be replaced an if so were from thanks a really pissed off me ,
    Users browsing this forum: Ahrefs [Bot] and 10 guests
