5 speed endplate issue
sydduckett
Putting a cyclone together and im struggling to get the end plate bearing over the christmas tree. Iv given it some light force but its way to tight really. I could give it a bit more of a whack and get it home but id never get it off. anyone else had this issue?
Ta
Sef
dutch
yeah had the same problem but just used a plastic hammer and tapped it on, if you use the bolts to get the end plate off and plastic hammer to tap the xmas tree back now and then it does come off.
sydduckett
Im so tempted to give it a whack but the end plate has always been a tight fit so im concerned that if i do whack it home, there it will stay. :?
I guess i need a couple more people to say the same and ill get my hammer out.... :D
ta
How did you get the layshaft in? It does take a little persuasion ;)
sydduckett
soulsurfer wrote:How did you get the layshaft in? It does take a little persuasion ;)
well i gave it a couple of whacks with a plastic hammer like you do. Thing is i can get that back out if i have to the end plate may be a different bag of onions though..... :)
john.t5
I used a real hammer :o Did have it on and off a few times though so no probs.
sydduckett
john.t5 wrote:I used a real hammer :o Did have it on and off a few times though so no probs.
so it was tighter than a normal set up? Feel the persuader is about to make an entrance.....
dave wheeler
mine was definitely tighter than usual, put the nut on the xmas tree before you attack it though
    Users browsing this forum: Semrush [Bot] and 18 guests
