PX 2 STROKE LEAK
djh66
Main scooter: 150 special
I've got 2 stroke oil leaking, only when engine is hot, from around the base of the carb (autolube). I took the carb off and replaced the carb base gasket, thinking this would solve it, alas it hasn't! Would it be the gasket under the carb box that needs replacing? (Which like an idiot, I didn't check!!) Cheers
Bring Me Sunshine COYH
The airbox gasket is the one that seals the oil galley from the engine casing.
