Series 1 Project 59 Frame Breather
Supereibar
so, there where Italian Lambretta 125's sold in England? I thought you guys only got from 150 up...
Frautzi
Well after well over 12 months off this project due to moving house and then having to set my garage back up in the new house, am now back at it.
Frame back from painters
Just offering up some parts ready for fit
Building the forks up, will fit them whe i get my new fork link bolts
I had to rattle can all the satin black parts, tank,toolbox,hubs, fork links and a few more.. just to keep the cost down where i could..
Thats all for now lots to do, plan is to get it finished for the 4 nations in september..
Frautzi
A little more progress.
Tank , rear light and mudguard in.
Painted the (chrome trim ring) satin black, loom in, cables and semi hydraulic brake.
SIP rims with racemans...
Legshields on, loose fit for now.
Tool box with , volt meter and fuel gauge. volt meter may be swapped for rev counter. just letting the rubber settle before cutting the mitres in the corners.
Still plenty to do....
Don't forget too pump them tyres up ;)
Frautzi
Might fill em full of solid rubber like them old bike tyres :roll:
john.t5
Only just seen this, keep at it - this is lush - everything about it so far is lush...
LI150
Main scooter: Series 2 LI150
looking Good :D
Supereibar wrote:so, there where Italian Lambretta 125's sold in England? I thought you guys only got from 150 up...
you may recall me telling you the breather frame I had was 125 and also a 59 ...the frame number on mine was also outside of thouse given on the lambretta archives (hence it been given a 59 plate),it can be only assumed these frames had been left over after the change to air box between the tank/toolbox and were then used up prior to the introduction of the series 2
gaz_powell
looking good !
nice to see all the black trim with satin parts - I`m doing the same on my S2 build at the minute
what ignition switch is that - I want to get rid of the kill switch
bazman
Looking nice jay :D
One thing though ditch those tyres mate :(
