jetex manifold
Noplastic
Main scooter: Vespa PX221 disc
Hello, does anyone know if the Jetex 22 manifold for Lambretta GP200 SIL fits Dellorto Phbh 30 as well? thanks in advance.
Donnie
It does not Im afraid, you need a bigger manifold
Donnie.
Noplastic
Donnie wrote:It does not Im afraid, you need a bigger manifold
HI, i dont know why i didnt get the notification of your answer. :roll: so i'm reading now. i could actually fit the manifold inside the carb the problem is that it bumps against the flywheel cover, also the throttle cable seems to be too short for a quick conversion.... :?
Noplastic
ok i forgot that you have to bookmark every topic you post if you wanna get notifications. Done now. I searched for a few manifolds but they seem to be pretty expensive such as this one http://www.lambrettaspares.com/spares/t ... 0521k.html with the same price i can buy a new jetex and save the phbh for the Vespa for which i already have the Malossi manifold that was included in the package.
DaveTomo
Main scooter: SX 200
you will also need a different choke cable and a longer throttle cable.the link you put up is for a TS1, are you putting it on a engine with the carb on the standard side? ( the left as your sitting on it) is it rubber mounted carb if so then this one http://www.afrayspeed.co.uk/index.php?p ... buteID=INL
Noplastic
DaveTomo wrote:you will also need a different choke cable and a longer throttle cable.the link you put up is for a TS1, are you putting it on a engine with the carb on the standard side? ( the left as your sitting on it) is it rubber mounted carb if so then this one http://www.afrayspeed.co.uk/index.php?p ... buteID=INL
thanks for the link! Do you have nay idea which lenght of cables i might need and how to modify the phbh choke lever system into a choke cable-system?
DaveTomo
cable choke kit http://www.dellorto.co.uk/merchandise/p ... ctionID=24
the above doesn't come with a cable, I get mine from a lad on here Martin Leech, username on here knowledge, do a member search then drop him a PM .
Throttle cable you want inner and outer and a solder less nipple most places sell them heres a few examples :
http://www.scooterrestorations.com/lamb ... -long-f-f/
http://www.scooterrestorations.com/lamb ... er-nipple/
http://www.lambrettaspares.com/spares/p ... 396gr.html
worth carrying a spare inner as well http://www.scooterrestorations.com/lamb ... ble-inner/
when you route your throttle cable its best to bring the outer down the same side as your gear/clutch cables and then loop over to your carb, gives a smoother action.
tonydevon
Main scooter: '71 GP125
these people are great, and way way cheaper than anywhere else I have used for carb parts, jets etc
http://www.wasp-performance.co.uk/onlin ... Choke.html
tonydevon wrote:these people are great, and way way cheaper than anywhere else I have used for carb parts, jets etc
+1 on that usually very good service.
Noplastic
I'm trying to figure out if on dell'orto uk they sell jets for SH/Jetex carburettors in order to replace mines. I tryed allstyle scooters but they don't accept orders for less than 100pouns oversea. Heer's a long list of parts but they're listed by codes... could anyone tell me which ones are those that i need? http://www.dellorto.co.uk/merchandise/p ... ctionID=51
