210 Malossi 28mm Delli settings required
thebassmasta
Main scooter: GP TS1 240
Im after some base settings for a 210 Malossi with a Dellorto 28mm PHBH and a PM Pipe.
This is how its set up at the moment:
Dellorto PHBH28
Main jet 128
pilot 55
Atomiser AV 250 or 260 (dificult to read)
Needle X2
Air screw set 1 1/2 turns out.
It runs well but just dosn't rev cleanly at the lower rev range.
It would be nice to just clean up the burbling at the lower rev range
MCH
Main scooter: street racer px
check your plug colour
also are you running it with or without a filter, or with the hose?
im running
Atom av262
needle x2 2nd clip
pilot 50
choke 70
main 122
air 1 1\2 turns out
with hose attatched,
still not got it bang on yet, going to try a 45 pilot,
depending on what filter your running depends on your jetting, im still experimenting but try going down leaner, but like i say keep checking plug colour
