Avanti and TM24
ScooterLoopyJohn
Main scooter: 1970 GP 195cc A/F s'type
Hi Avanti with a 60 stroke and 24TM carb and air box . 185 main 22.5 pilot needle 5n13 top clip very close to perfect. will repost after dyno
Agent Buchwald
Interesting to see if it acts as a restriction anywhere - could you post with what Ron would expect from the same engine with say a PHBH 30mm or whatever he recommends?
Watching with interest :)
OAP
Me too
Ditto
Honeymonster
What exhaust are you using SLJ? top clip on a 5N13 is usually lean but what atomizer are you using?
I'm running the TM24 on a 60 crank with an RT 220, breath easy filter, LTH stage 6 reed valve and MB clubman, current setting are, 25 pilot, P8 atomizer, 5N13-3, 3mm slide and 200 main but still running in the high 600's, have been looking at a low compression head from Mark to look for more cool running.
Will be interested in your dyno results.
Ian
mick1
Main scooter: Li Avanti 225
Any updates ??
