Head cowl removal.
bazza3004
Got a gp fitted with a Sterling pipe (standard exhaust stub),and would like to no if the head cowl will come off with u bend in place.
Thanks,Baz.
dapper
IIRC it may be possible if you remove the rear shock first.
dennis
Main scooter: 1 gp 1 special
Mine does with shock removed.
bazza3004
cheers lads . had to loosen u bend and wriggle it abit but managed it. trickiest bit was getting the bottom cowl bolt back in the mag housing as bugger all room between head cowl and pipe. got there in the end though. thanks again.
