175 carb
sydduckett
I have a 175 top end and a 19mm spac carb with a scorpion exspansion. Wondered if anyone had a simailar set up? If so what sort of jets/needles are you using. Failing that can someone tell me what the TV175,s had on them carb wise and what jets. at least ill have a starting point.
Thanks
Sef
Tony Hart
Main scooter: Lambretta S2
The S3 TV had a 20mm carb (Dellortho SH1/20 with 106 main, 50 pilot and the usual 50 starter. 5914-1 slide and 5899-2 atomiser completes the settings). Hope this helps
sydduckett
Tony Hart wrote:The S3 TV had a 20mm carb (Dellortho SH1/20 with 106 main, 50 pilot and the usual 50 starter. 5914-1 slide and 5899-2 atomiser completes the settings). Hope this helps
thanks Tony, at least i know where to start now.
    Users browsing this forum: Baidu [Spider] and 6 guests
