Gearbox end plate bearing
bazza3004
Hi . going to replace the end plate bearing (the one for the cluster) and just wondered how tight a fit they are. Could i apply some heat and tap it out / in or will it require a press. thanks.
Some heat and tap it out, usually not that tight.
bazza3004
Thanks for that.
bazza3004
swapped it for a new one today . as you said bit of heat and it tapped out / in no problem. thanks again.
    Users browsing this forum: Ahrefs [Bot] and 1 guest
