Is this a Stage 5?
Here's what Babelfish made of it. :D
Cylinder Lambretta of 200 steam turbine and gas turbine systems 5 Cylinder for Lambretta 200. So far to me is concerns it admits steam turbine and gas turbine systems 5 cylinder, which was geportet in England. The cylinder is not appropriate now already eternally with me for rum and I has use for it. I assume it was for at that time the very much belibten Conversion change with Honda pistons. The diameter is measured 66.4 mm. It looks as again gehohnt and so surely yet did not run. Under the discharge opening pieces cooling fin broke off.
