series 1 engine case and mag flange
tea5ive
Main scooter: cometa 140
upgrading a series 1 li150 engine to electronic and gp crank and a rebore to 175cc. I take it I can use the original mag flange with the nu2205 bearing ? . is there anything else I should be aware of ?. also the gear box is an early 125 would this be ok to use ( 175, clubman and a phbh 28mm) ?. I should know all this but have had a bout of brain fade :? . cheers simon
psychedelicropcircle
No youll need to change the mag flange. if i remember right the bearing was lubed by the petrol/oil. gearbox etc should be fine.
