sip long stroke t5 crank
soulboy
im totaly lost with all that i just need to no is it a fit and forget part i/e only mod needed is the packing plate
tony
Main scooter: 90ss
To add the extra area you may need to be clever or weld around the studs Darrel. But at least that means you may be able to use a pipe that us available keeping costs down on the custom pipe front.
There is no plug and play solution tbh
soulboy
thanks tony they dont tell you that i wont bother goin that route my cranks cut and polished anyway
cezeta
soulboy wrote:thanks tony they dont tell you that i wont bother goin that route my cranks cut and polished anyway
ditto, too much aggro. i need to improve the power outside the power band with a taffy pipe. drops out of the power on a hill and im buggered and the mrs on a standard p2 disapears into the distance.
i was hoping this would be the easy fix......for sale t5...wanted tx200 with polini kit.
    Users browsing this forum: Google [Bot] and 7 guests
