Casa Lambretta Direct drive system
well i think a disadvantage would be that if you got the gearing wrong its gonna be expencive to change it
RICSPEED wrote:well i think a disadvantage would be that if you got the gearing wrong its gonna be expencive to change it
From a changeability perspective I think that might depend if they've been smart enough to engineer it so the cog diameters are the same but change the teeth numbers and profiles, which is what I believe has been done with the cyclone, but I think you can safely bet it will be expensive ...
Grumpy225
Weston-scooterist wrote:I'm no engineer, can someone more knowledgable tell me the advantages of direct drive over chain drive?
Trying to recreate that classic Vespa clunk when shifting in to first?
TED CRUD
well i am not a fan of chains +guides or belts .I drive Lambrettas and a iIaljet dragster and had very bad experiences with both ,but come to think of it i blew up
a vespa cush drive that locked the back end up solid at speed ,Fook me looking back i am either cursed or lucky ?!?!
Smash Ya Pastie
Washington Posse s.c
goldeneye
you? unlucky? I would never have guessed! :D :o
MarkH
The center gear is actually under no stress at all - it spins freely on a bearing. There's more stress on that mounting area with a chain tensioner in place.
I'm sure someone has tried this before but Vittorio says he's had this idea floating around in his head for several years. It's an interesting R&D project at the very least and often leads to new ideas. Can't fault him for that. Doesn't mean it's coming to market. The point of direct drive is to eliminate the power loss that a slack chain would give.
so as long as your capable of adjusting your chain teshioners ,taking up the slack by regular servicing and maintainance etc ...no advantage then ?
TED CRUD
goldeneye wrote:you? unlucky? I would never have guessed! :D :o
Well it depends on which way you look at it GoldenEye ;)
Smash Ya Pastie
    Users browsing this forum: Amazon [Bot] and 5 guests
